So it sounds like a business opportunity to make a quality designed part that is machined to spec in such a way as to prevent any sort of slop in the mounting locations.
Alright guys, I've been contemplating this a bit more lately. I remember reading a while back I believe about someone having an issue with their flywheel bolts loosening up. I haven't torn into one of these cars at this point in my life to look at the design and how the clutch/flywheel/pressure plate assembly is assembled but in the event that somehow the bolts that hold the flywheel to the crankshaft or the pressure plate to the flywheel loosened up enough to allow slight angular deflection could that potentially be the issue?
No.
If your pressure plate bolts loosen (as they did on many 2011's), you'll lose the ability to shift the transmission. If the flywheel bolts loosen (very unlikely), you'll experience rattling, vibration, and starter engagement issues.
No.
