Engine stalling and dies few minutes after start
PawelS
Huntersville, NC
Hey guys, it’s a pleasure to join the community.
I was happy 2005 V6 convertible mustang owner until now…
I was driving back home with tie rod ends (what an irony) and suddenly car starter to stall and died on the highway.
I towed it to the dealership and they “diagnose” faulty alternator, battery, fuel pump and FPDM… I blindly believed the dealer and changed all of these parts excluding battery (just charged it and it works great so far), but nothing seemed to help.
It’s still starting and after few (3-6minutes) stalling and dies.
The only recurring fault I can read is P0191.
I thought it may be clogged filter so I changed it right now, but that also didn’t work. When motor runs I hear this weird intermittent humming noise from the exhaust, but nothing else seams to be bad.
Is anybody here who run through similar situation and found the reason?
Thanks for any advice.
MrBhp
Fuel rail pressure sensor is either not liking the data it's getting. Or it's going bad. If you've another round for the parts shotgun, get another sensor. If you are tired of spending money, try to test out the fuel system before you spend another dime. Hopefully you are not missing work or school because of it.
PawelS
Huntersville, NC
Thanks for your reply.
I ordered pressure gauge and it supposed to arrive today. Maybe I’ll be able to check the pressure, what should be my first step after bringing car from the dealer instead of changing parts like crazy…
Well, people learn on their mistakes.
Bank 1 means the one the driver side?
I skipped over 2 days of work because of that, but I did rent a car, so I’m good now.
I’m trying to understand what happened to my vehicle and why dealership diagnosed all these components to be faulty at the same time, I just don’t get it.
Is there any chance of testing this sensor? I do have OBD2 scanner and it shows most of parameters from PCM,
Just don’t really know how to interpret these.
By convention, bank 1 on any Vee engine has the cylinder that's furthest towards the front of the engine and is numerically the no.1 cylinder. On the 4.0L V6, bank 1 is the passenger side.
I do. The stealership was looking for an excuse to fire the parts cannon and lighten your wallet without bothering to troubleshoot the problem.
The obvious item to focus on is the P0191 code for the fuel rail pressure sensor. When this goes bad, a common symptom is random stalling. This article may help with troubleshooting it.
PawelS
Huntersville, NC
thanks for the article. I will check the fuel pressure whenever the gauge arrives, like also try to upload video on YT and share link with you what can be helpful.
It runs until temperature reaches some point, I would say approximately 50deg Celsius, at least that’s what I’m reading from the scanner.
When I spoke with mobile mechanic he mentioned that it looks for him like the wiring issue, either pcm -> fpdm or fpdm -> fuel pump.
That’s something I didn’t check yet. That is on the list in the case of fuel distribution issue checked by gauge.
I’m not sure if that’s the right direction, but I fully agree with stealership name…
Crazy, how untrusted they can be, when they should be the best specialists for diagnostics.
I uploaded videos:
Stalling
Parameters
PawelS
Huntersville, NC
I finally hooked up the fuel pressure gauge and I found something what can be a good explanation.
First picture is a pressure built, second is 40 minutes later to check possible gas leaks on the injectors and the rail and 3rd is a value read by the fuel rail pressure sensor.
These are definitely not matching.
In this case I’m going to swap the sensor and check if that was an issue.
It’s the most logical explanation for me at this point. too high read from this sensor causes PCM to drop the pump pressure down.
I’ll keep the forum posted in the case if somebody will have similar issue.
Your fuel rail pressure sensor is reading the equivalent of 51.4psi. That's a huge discrepancy from the 34psi (normal) that your analog gauge is reading, and that would explain why you have the fault code plus the engine stalling. Hopefully a new sensor will fix it.
As I said in my previous post, bank 1 is the passenger side.
PawelS
Huntersville, NC
Sensor has been changed and no improvement. I would say it’s even worse. It doesn’t die after few minutes, but below 1 minute now.
Pressure read from the sensor is relatively lower comparing to the previous sensor, but now the pressure from the pump is coming to the gauge but engine dies quickly.
Any other idea what can that be?
I’m loosing my hope…
This is a proper headscratcher!
What fuel pressure reading do you get from the OBD 2 scanner and how does that compare to the reading from the analog gauge?
Has the ECU triggered any new codes?
I'm wondering whether you might have solved one problem and unmasked another.
PawelS
Huntersville, NC
@Dino Dino Bambino
When engine died gauge was at 35PSI and the read from sensor was approx 290kPa. The only thing I noticed, it’s showing the pressure relative to manifold and it’s not matching the gauge exactly.
It is a head scratcher and some kind of mystery.
Fault stayed the same P0191. I’ll try to get somebody to help me with cranking and I want to measure all voltages coming to the pump driver module, including control signals/feedback however it’s called.
I’m missing something for certain.
That is incredibly weird, because this car has only 65k miles on it. No leaks of oil, gas, coolant, fumes, engine is perfectly dry and clean.
Here’s the question, if there would be a problem with throttle body or either clogged exhaust, would the PCM throw the related faults, or not necessarily?
Rotgutrusty
Tampa, FL
I’m having this same problem, OBD is scanning 65psi and gauge shows 35psi. Changed the fuel rail sensor but the problem persists. Have you come up with anything yet? Before this discovery all my signs were pointing to bad PCM.
PawelS
Huntersville, NC
@Rotgutrusty
Unfortunately not yet. That is my next suspect, the PCM.
It has a communication with obd, but might just faulting out internally. Maybe somebody can give a hint how to check PCM other way than swapping with a working one?
If you will fix the problem, let me know. I really want my car back. I have to drive fiesta… ugh… no remote door lock, no cruise, no fun at all. How to live?
Dany
California
Hey im having similar issues with my 2010 mustang v6, it has a p0191 code even after getting the pcm opened up and repaired, i replaced the sensor and nothing changed, new fuel filter and o2 sensors and egr valve and nothing changed. Any suggestions or what worked for you?
PawelS
Huntersville, NC
In my case it was not compatible fuel pump drive module. I changed this module with a pump but after installing the original one back car works fine.
Eman
E Tennessee
I was wondering what adapter was used to give access to a manual pressure gauge. I have plenty of gauges but there is no schraeder valve on the rail that I find.
PawelS
Huntersville, NC
It was a set from Amazon, and yeah, there’s not schrader valve at all. I had to disconnect the fast connector between fuel rail and tank hose. It’s right under the driver’s side fuel rail. It’s tricky to unlock it without a proper tool, though.
The adapter included in the set was a perfect fit. I attached how it looks like.
Eman
E Tennessee
Thanks for the pic, I'll have to find one. I did search and find a post with a link to an S&G Tool Aid adapter.
As for the problem with stalling and the codes while searching I saw some had connector problems at the fuel pressure sensor. If the connector at the sensor isn't making good contact it can't send the correct signal back to the PCM even if the sensor is good. Checking for correct power and ground at the sensor and tightening up the terminals and cleaning of needed might be the solution.
For what it's worth:
Whenever I see any code that has "Sensor A Circuit Range/Performance", that sensor is disconnected from the pcm. (or not there in my case, but you get the idea)
From what all has been tried, and NONE of it helped, I'd say the issue has not been found yet. I'd bet on a wiring issue of some type. Suggest the "Wiggle test" while monitoring OBD fuel pressure. Does not need to be running, just key on.
