one eyed willy
Pizzle fo shizzle
I can't wait to see how the lines flow with the rear of your car.
In terms of the fenders, would it be easier to buy some 2010 fenders, cut them down the center of the wheel well and then weld the 05 fenders on to it from the cut back?
it could be done, but you need to retain the entire top section of the older fender. the newer fenders have a much sharper edge on the top and its slightly raised on the outer corner. if the front lower quarter section from just below the top fold could be cut and welded to a older fender....it would work. if i find a set of fenders for cheap, i may try it.
main reason i didnt try this before was i didnt know if the top portion of the older fender would match the contours of the newer hood lines. if i put my older fender on, next to the newer hood, it matches perfectly.
