ChiDiddy
you sir have a beautiful build!
I need to stop by and check it out some time. I am in the area several times a week.Thanks man! It's getting closer to running again. I really think I could have it running in about 3 weeks or so if I quit forgetting to order the last little pieces I need. Then I'll just need to go through my trans and upgrade a couple of parts I already have and install my new converter.
Are you talking about like mine, but single turbo?Sick build!!! Subscribing.
Wish someone would build a single reverse that clears the AC.
I think so, but I haven't tried yet. Once I pull the motor to paint the engine bay I'll let you know. The headers could sit a little lower, but I did them higher to position the turbos where I wanted them.awesome...can you get the valve covers off w/o removing the headers?
Yup, I know JPC had a system that reversed the stock manifolds but didn't clear the AC unit. Looking at your header design it looks like you have a lot of clearance for the accessories.
Not to thread jack but Possibly using this same concept.
I can get to all of the bolts, but I may not be able to clear the cam timing sprocket before the valve cover hits the header. I'll let you know for sure though.maybe a 1/4 inch swivel and extension
That could definitely be done with the way the headers are and you could keep a/c and power steering. I'll be building a setup like that for a friend soon and he will probably post pics as it progresses. It will be a T6 single turbo with 5" downpipe to dual 3.5" downpipes.Yup, I know JPC had a system that reversed the stock manifolds but didn't clear the AC unit. Looking at your header design it looks like you have a lot of clearance for the accessories.
Sounds like something you might want, lol.thats a good idea![]()
