Friction modifier
RocketcarX
95% of my weight is fuel
Colorado
I was wondering about that. Wonder why Ford would leave out those additives when virtually every other 75w-140 gear oil has them? Would there be any adverse events if the Ford modifier is added to the RP gear oil?
If it is a fresh rebuild (new clutches) it doesn't matter what fluid you use, it will need at least 4oz of additive. Most times this is true of a fluid change as well.
WJBertrand
Nope just a maintenance change for POM. I will go ahead and add the modifier. Already bought it anyway. Amazon is your friend.
Netherlands
Zijn er veel mustangs in de Nederlands? Mijn nederlands is niet zo goed als vroeger. It's been almost 30 years since I was there. I went to an international boarding school in Eerde, just outside of Zwolle. I lived up north in Groningen.
The Ford stuff should work out for you, or royal purple.
Cool! No not many at all. Even though the S550 is officially sold here, they are so heavily taxed that nobody buys them. 60/70k for the ecoboost and 120k for a GT.
Dayum! I can buy a GT350 here for that kind of coin.
RedGt
Europe
Tax for high powered cars I sky high here in the Netherlands, changed my diff fluid (28.000 miles )with mpm oil and has friction modifier in it.
RedGT
07 Boss
Sin City
Because that way the can run it with all their differentials. You only need friction modifier if you are using a clutch style posi.
RSIII
East Coast
You will need to add 4oz of friction modifier. Have changed several 8.8 Ford diffs gear lube and all had the slow tight turn chatter without the modifier even though I tried several synthetic gear oils that said they had the modifier already in It. 4 oz of the Mototcraft modifier does the trick. I usually run Lucas synthetic 75-140 gear lube.
Netherlands
Went to the local ford dealer, they had a S550 GT on sale in the showroom. Explained what I needed, even gave them the part#, still looked at me like the saw water burning.... guess I'll order some from ebay or something.
tjm73
of Omicron Persei 8
Rush, NY
Does friction modifier stop working? My '07 F150 5.4 (124,000 miles) has a traction-lok and in the last 1,000 miles or so it has started to have slow speed clutch chatter in the axle. I m not interested in rebuilding the traction-lok, but would like to stop the chatter. Have thought about putting more friction modifier in it.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Any jeeps over there? I've used the mopar stuff when I needed some on a Sunday and it smelled, looked, and worked just like the Ford stuff.
Netherlands
Thanks for the advice, might check next time! For now I just ordered some from ebay, 25usd total. Not too bad
