The lines came off my car and are lightly used, all 8an aqp startlite lines and fittings/hose ends. The Fore f10 filter is new with the reusable stainless steel element and orb to 8an fittings to plumb it in, all e85 compatible. At the hat it has the oem style quick disconnect fitting installed and for the rail has the larger inner diameter efi fitting. This setup is ready to go on and easy to install using the stock line routing and filter mounting location. Will drop duty cycle 20%+ depending on setup.
$250 shipped
Info on the Fore filter and ss element.
http://www.foreinnovations.com/product_p/16-900.htm
Some pics of the install on my car and info on the setup.
http://www.s197forum.com/forum/showthread.php?t=91591&highlight=fuel+line
$250 shipped
