how much power can a PH TURBO KIT MAKE WITH A 67MM
n/a3valve
i was wondering if any of you had the powerhouse turbo kit with the 67mm turbo . If so what kind of power have you made with the 67mm.
i would be running a stock but forged shortblock no head work or cams.
WHAT WILL THE LIL 67MM DO ...
My first turbo on my kit was a 67mm from a powerhouse kit.
The powerhouse kit comes with a precision PTE6776 cast wheel turbo with a .96 ar housing and and an E compressor cover. It would be quite healthly to around 600rwhp. I wouldnt run anymore that. Sure it will make more but you will be going outside the efficiencey range. I made 604rwhp with that turbo before switiching to a cea billet wheel 6765.
Bobby
turbo gt about to go fast
i made 607whp and 677wtrq with a 62mm turbonetics journal bearing cast wheel turbo @18psi on 93 octane. that is with a .81 housing. so with a .96 it would have made more. is that tells you any thing
Redfire
I don't have any dyno numbers but I went 10.31@133 weighing around 3800 with the 67mm. I can't remember how much boost I was running but the turbo had no more to give.
