Installing a paxton novi 2200.
calgarybandit
Just finished my 8 rib Vortech JT with a return style 450lph Fore innovations fuel system -10 feed -8 return, FC3 controller, high flow fuel rails, ID 1000 injectors, fuel regulator and 3.48 pulley.
5PointOHNO
Interesting that you went for a different fuel system.
Was it because you were going to run more boost (for all I know, you have a lower compression short block).
onebadgsx
Houston, TX
I did it to run e85, I also don't feel comfortable running more than 650 HP on stock pump with bap.
calgarybandit
Stock block for now but I did the fuel system for built block this fall my target is 800-950 in the near future.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
D98GT
STREETCAR
Liberty TX
So if one were to use radiator paint on the intercooler....negative effect on cooling or anything?
I'm not sure I want the satin silver hanging in the opening; thinking that black would look a little less obvious
onebadgsx
Houston, TX
should not effect anything. my old turbo car had a black painted intercooler. iat's were the same before and after
D98GT
STREETCAR
Liberty TX
That is good to hear; these are small things I can accomplish before I totally figure out the install.
I just need to buy the NGKs as I sold my brisk plugs; I think I have the other important items other than the other clamps that you guys mention.
D98GT
STREETCAR
Liberty TX
Guessing I should buy the actual radiator paint instead of engine enamel as I definitely don't want to block any of the openings.
whtcanbrwnd04u
San Marcos,TX
Wheres the cheapest place to get the NGKs?
D98GT
STREETCAR
Liberty TX
I ordered a set on amazon for $70.92 shipped to me.
Thanks to Jason (onebadgsx) i've ordered a few parts just today including the plugs and t-clamps for the entire kit. The clamps came out to be just over $100 but i'd rather just have this done once and the best way.
whtcanbrwnd04u
San Marcos,TX
Do you mind posting the links? Thanks
-Ali
