ITS HERE!!!!!!
MindIfISmoke?
Wrecking Crew
Puyallup, WA
Call Eric he will square you away! I was told the next batch of pre- production ones will be available in 3-4 weeks.
Sent from my phone. I'm driving
Kidd
Berea KY
Holy CRAP man that is an awesome looking intake! what did that set you back? If you can say lol ;)
Sent from my SAMSUNG-SGH-I777 using Tapatalk
MindIfISmoke?
Wrecking Crew
Puyallup, WA
Well with our forum discount it came out to 802$ shipped to my door! Man I couldn't be happier. No offence but no other intake manifold for our 3 valves can even hold a candle to JPC's.
:highfive:
Looks good! I really like my frpp manifold it made good power, is lightweight, looks good and was a great price, but now that im going to be turning up the boost past 16psi I don't want to risk it with the 2 piece composite frpp so I def will be picking on of these JPC cast manifolds up when I can!
MindIfISmoke?
Wrecking Crew
Puyallup, WA
This one is heavier... but it's not that bad. I almost got the FRPP. But at the last minute Eric called me and said my number was up! He also said they never anticipated this much interest in them.
I Imagine this will perfrom just as well, it def looks better and is lighter than the c&l though which I like. With the turbo at 12psi on my car the frpp picked up peak gains of 32rwhp and 30-40rwhp in the midrange, gains started at 3000 rpms. I would suspect you will make similiar gains with the JPC intake on your turbo setup. Turbo cars respond well to aftermarket intake manifolds.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
Eric told me with my setup where the stock intake would normally stop making power this one SHOULD net around 50rwhp more. But I would be happy w/ 30. I think with my compression ratio and a couple other goodies I should make 600+ whp @ 12psi
With 9:1 compression on my stock displacement 281 with stage 2 comp cams and the frpp manifold, I made 563rwhp at 12psi 16 degress of timing, so its very well possible! When's it going on! lol
MindIfISmoke?
Wrecking Crew
Puyallup, WA
I'm 10.5:1. Stock cams. 20° limiter. Built 302. Check out my build thread I'm actually in the process of putting her back together now.
Yeah with the 10.5 and the stroker, thats good for 30-40hp over mine boost for boost right there. What injectors and pumps did you go with for e85?
MindIfISmoke?
Wrecking Crew
Puyallup, WA
SD 80#ers... gt500 fuel system w/ dual kb boost-a-pump..... i may buy that fore setup off you.... ive been watching it lol.
Well the gt500 system on pump gas is good for 600-625rwhp with baps 750-800rwhp tops. So e85 uses around 25% more fuel. So .25 times 800rwhp puts you in the 600rwhp range, will be close.
