AutoXRacer
I had my crank bolt back off & the pulley started to work it's way off. Actually started twisting the keyway on the crank. I only found it after pulling the motor when it blew (not related). When I did my next motor I had the crank double keyed & used the longer ARP crank bolt so it wouldn't happen again.
So what balancer do you run with your double key?
So I hate to bring up this awful subject, but it came up when I was checking out on of the local machine/engine building shops.
A comment was made that having vacuum though the PCV system allows much better ring seal.
But that with these motors, a lot of oil is sucked into the intake, which at my power levels is not desired.
So, where does one stand? I want better ring seal, but don't want the oil.
According to the shop, with a blower motor, you are always going to have blow-by.
I really don't want to get into the whole adding an electric vacuum pump and all that jazz. I just have no room for it in my engine bay.
So whats the deal? Is there really that much to gain with vacuum in the PCV system/shortblock?
The shop kept saying you can make a lot more power with vacuum present.
Has this even been proven?
I frankly hate this subject...
Also after the conversation, seems like I will be doing a full rebuild.
Although, the shop does agree the failure most likely is isolated to the heads. But since I am partly there anyway, might as well just rebuild the block. Plus, in order to inspect it, you need to pull the pistons to see how the rings wore and by that time, might as well not put the old parts back in.
