JPC Cams tested, Dyno sheets inside
Wicked97
Beltsville, MD
Stock Number
JPC Cams
Its the same Dyno sheet with the 2 diffrent Peak numbers showing
The test was done on a Auto car
JPC full exhaust system
C and L intake
SCT tune
with 4.10 gears
Test was done same day, We actually swaped the cams on the dyno.
Whocares05050
I am VERY impressed with the numbers considering its on a dyno dynamics ( these always read the lowest for me ) and with the 4.10 gearing on an automatic. the before and after is the real show here though. I am interested in staying all motor, and would want to go this route eventually. the cams are going to run about a 1000. Does anyone know what the average labor is going to be to have someone install these on our motors?
Wicked97
Beltsville, MD
Damn impressive. Would you be able to overlay the graphs
im not sure that i follow you
I did over lay them the smaller graph is stock the bigger is with the new cams.
I just did the 2 sheets so you could see peak stock and with the jpc cams
Edit; sorry already answered i was stuck on the phone and could not finish my post
Intervention
Yeah that is stock heads.
Possible to see it with RPM and Torque added?
DO you guys see any durability issues with stock springs? will they weaken over time and cause some interference with the slightly higher lift?
Also, I assume you need a new tune? My point is, will there be interfence without the tune? Can I drive from my mechanic to my tuners shop witht he cams installed buy not tuned?
Whocares05050
Eric, im not going to drive from FL to MD to have these installed, but to get an idea of what it would cost, how much would you guys charge for labor to install these on a 2011 5.0?
Thanks.
