I had it on jack stands and it rolled fine, and like I've said it's did it on three sets of wheels. Also for the one wheel things about the way the suspension links into the rear end, the drive shaft and the way the limited slip works. There aren't mounts on the outer most edge of the the axles besides the lca's this allows a certain about of play for the rear end to move upward. A unbalanced drive shaft only spins one way while the car is in drive creating a upward and downward force in that one direction while its spinning, like a person spinning with a weight on a string. That combined with the limited slip locking that wheel up first, you have a recipe for unequal forces acting on one wheel. Like I said, it only broke when I lost traction, not under normal driving conditions. I've gone 10k miles with out a burnout, got a bit loose leaving a light to get on a on ramp. And pow broken wheel stud. Did the same thing, no vibrations over 80 mph like I had before and no broken wheels studs...
