Kenne Bell question
usmcpony
I have been tihinking about getting the new 2.8L from Kenne Bell when it is introduced to the public. Initially I was going to have my block built at the same time but I cant at the moment due to a law suite against my body shop. I plan on building my block in approx. a year. So my questions are
1. can I use the 2.8L with a stock block without blowing it up or should I get the 2.6L?
2. If so would it be efficient since the blower is going to spin slower?
3. With the 2.8L or 2.6L what 1/4 mile times should I expect? (Average driver, 5 spd, full exhaust, and 373)
4. What options should I get? I know I want polished with the 8 rib. Is there anything else I can get?
5. Whats the most RWHP you would recommend and what pully would I need?
6. Is there anything else I would need such as clutch, diff. gears, etc.
Thanks for the help.
__________________
2007 Mustang GT, Cervinis kit, Alloy with painted tungsten stripes, Kooks LT, Kooks catted x-pipe, Magnaflow catbacks, Eibach pro-kit, 20" raceline rims
05mustang_TT_charged
Because Race Car!!
LSU Country
1. I would say NO because the stock motor will not support the amount of HP the 2.8L kit will make, unless they have a pulley that will make around 10 psi. but spinning the blower that slow will only hurt performance.
2. Probably not.
3. I would say with the 2.6L and good tires should be low 12's to mid 11's
4. Upgrade injectors for when motor is built, a GT500 fuel system.
5. The 3.75" is 10 psi. the 3.5" is 12 psi.
6. Deifinetly a clutch maybe a Spec 3+, Detroit Tru Trac, and the 3.73 should be fine.
The 2.8L kit is meant to be a Competition kit, it is being designed to make big HP. I am not sure if it will make a tame amount of boost for a stock motor and you would be spinning it so slow that it will not be very efficient. I think they are designing the kit for 20+ psi.
mygt500
Stangpede Co-Captain Michigan Chapter
Clinton Twp, MI
I have to agree with what 05maustng_kb_charged and get the 2.6L. The same would be true if you wanted the 3.4L whipple for the stock block instead of the 2.3L....JMO J
Hatchman
Stangless
Chesapeake, VA
1. Go with the 2.6L, can still boost it up to 25psi, so lots of room to go
2. 2.6L is pretty effecient, even more so for a street driver.
3. Low 12's , maybe high 11's, mid 12's easy
4. Spec 3+
5. 10psi should give right around 480 rwhp.
6. I needed clutch, bigger tires, and felt the need to upgrade the brakes (hawk pads are nice improvement and cheap). Drive shaft is nice too.
__________________
2007 Mustang GT, Cervinis kit, Alloy with painted tungsten stripes, Kooks LT, Kooks catted x-pipe, Magnaflow catbacks, Eibach pro-kit, 20" raceline rims[/quote]
