GlassTop09
Hello All,
New to forums but I was wondering if anyone here has run these cams. I'm looking at possibly getting a set of these to run in my car.
Not looking for a lopey cam like the FRPP Hot Rods, Brenspeed Detroit Rockers or Comp Cams Thumpers\Mutha Thumpers but a set of cams that perform very stock like at low RPMs w\ very little to no low end TQ loss w\ good idle but do provide increased mid to high end HP & TQ gains vs the stock Ford OEM cams.
I haven't heard of or read of anyone using this particular set of Lunati camshafts in the Ford 4.6L\5.4L Modular Engines but they offer 12 different VooDoo cam profiles for these engines so I was curious if anyone here has run them. The Lunati VooDoo #21270700 cams are the mildest ones they make & from looking at the cam info given on their web site they seem very comparable to Comp Cams XFI NSR Stage II camshafts cam info in expected performance envelope.
Planning on staying NA w\ this build (mostly cruiser\car show duty) & have installed the following engine wise: FRPP "Bullit" 85mm CAI, BBK 62mm TB, FRPP Intake Manifold, Kooks 1 5\8" LT headers, Kooks Catted X-Pipe, Pypes Super Bomb Mid Muffler catback exhaust so all that is left to do is install a better breathing set of cams on an otherwise stock 4.6L bottom end to finish it up. Has been dyno tuned w\ the parts mentioned above & the OEM cams to 331HP\326TQ (from 273HP\275TQ stock) on 91 oct pump gas. Have a set of FRPP Black Wrinkle Coated Etched Valve Covers to install when the cams are installed.
Would appreciate any feedback on these cams if available.
Thanks!
Thanks!
