lethe
V4g!n@ #er
Looking good Marc ! It's going to be a cool tow rig for sure.
Sure, although the operating costs are a bit higher than a car or pickup. Fuel will cost double of what you would spend even with a pickup, and every single maintenance and repair item is more expensive than your average car. My C8500 with a Cat 3126 takes 20 quarts of oil and the air filters are $60 and $30 (yes, it has two air filters). Tires are about $500 each and last about 20K miles.
Took it for a spin today.
The smoke mostly clears out after the turbo spools. After the pump mods, I picked up 40% more hp and tq. I spent some time trying to figure out the drivetrain loss for medium and heavy duty trucks. Every shop that I talked to said it's 30%. Using that number, the truck is now making 305hp and 714 ft lbs at the flywheel. I just finished installing the boost and EGT gauge. Empty, the highest I could get the EGT was 800 degrees and it now makes 26lbs of boost. Oh ya, I adjusted the governor so it now revs to 3100 RPMs.
Does that have a bosch MW pump?
heres a cool pdf about the MW pump:
http://www.w124performance.com/docs...esel_Service_Training/PreTech_4.3_MW-Pump.pdf
We need vids!
Sent from my helicopter
Thi was when it was still stock.
Swap pumps out. P-pump FTW!!!
Those are so easy to hop up its unreal. And they can support an insane amount of power.
Misspelling courtesy of my fat fingers...
