MindIfISmoke's? Built Part 3.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
It looks alot trickier then it is my friend. Most of your time is devoted to unfucking fords wire loom/electric tape job.
Sent from my phone. I'm driving
SherrodMustang
Montgomery, Alabama
Yeah, pulled all the wires out of the oem harness that runs all the front lights a few weeks back. Lord what a mess of electrical tape. Nasty, sticky mess..
Kidd
Berea KY
Good luck!
Wire tuck is something I would love to have... But not sure if I am ready to tackle it yet.
This is me! Im terrified that I would end up yanking some wire loose and not realizing until everything was done, and then having to go on a wild goose chase to run down the problem.
Sent from my SAMSUNG-SGH-I777 using Tapatalk
Marc s
NASA AIX
Auburn, WA
The blocked cleaned up with a .010 over bore and did not need a sleeve. File fitting the rings now.
Marc s
NASA AIX
Auburn, WA
Thank you all very much! Hopefully ill have the short block tomorrow!
I got the crank in, the pump torn apart and cleaned, the pan cleaned, and the pistons hung on the rods. It was about 8:00 PM and at that point, someone brought out the Yamaha Rhino's and then dared me to a hill climb out back. So I'm sorry to say, I got a little distracted. I will go in tomorrow morning and finish it. It will be done late afternoon and will give you a call. It's turning out nice, the bores and the ring end gap are perfect. It should make good numbers. You should talk Andy into porting the heads for you since they are off.
BruceH
BBB Big Bore Boss 322
"Someone" My off topic question is did you make it? If you didn't was there an end over end involved?
MindIfISmoke?
Wrecking Crew
Puyallup, WA
If Andy is willing to do it for lunch on me than I'm in lol!
