MindIfISmoke's? Built Part 3.
Good question do you need some kinda of vented cap so you dont create vac in the tank as fuel goes down?
killswitch_c
Wsmr new Mexico
Hey guys I was just reading threw this thread fill free to chim in if you can help my car since I did my bulid smells like gas fumes in side the car and wanted to know if the evap system had any thing to do with it
Sent from my DROID2 GLOBAL using Tapatalk 2
Just dont pull the motor!
Gutted the trunk yet?
There are also 2 child seat anchor bars behind the back seat you can unbolt, thats like 2 lbs weight savings too! lol
lito
Caracas, Venezuela
Stock cap is check valved so it can suck air in but no leaks out so it gets pressurized, a pressure transducer gets that info to the pcm and then the pcm duty cycles the purge valve to relieve that pressure by calibrated amounts at certain engine conditions.
The thing is this, If I am not wrong, when you put a vent into the filler neck but do not change the cap you basically had not changed a thing.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
To easy!
one eyed willy
Pizzle fo shizzle
Lakeland FL
yes, the fumes will build up and get into the cabin. When i did mine i ran a hose off the vent to the rear muffler area just around the top of the tip so you can see it, i also reused the small foam filter to keep anything from coming back into the tank from that vent hose. all has been well.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
Uh ohhhhhh
JoshK
Modder AKA Fuel
Nebraska
Gotta do something while waiting on parts huh? Nothing else to tear off the car for now?
MindIfISmoke?
Wrecking Crew
Puyallup, WA
MindIfISmoke?
Wrecking Crew
Puyallup, WA
