MindIfISmoke's? Built Part 3.
:lol:
Well I was thinking it could be a simple thing with fan settings
MindIfISmoke?
Wrecking Crew
Puyallup, WA
I'm working on it! I hate troubleshooting small issues! I think Jeremy@s&h has come through for me once again! I don't think my high speed fan was kicking on!
JoshK
Modder AKA Fuel
Nebraska
What was the issue matt, i think we have identical setups on that. How did you figure out it was kicking on high?
MindIfISmoke?
Wrecking Crew
Puyallup, WA
i am going to do the test this morning. I think I let the car warm up to where the fan kicks on... then turn on the a/c. then if the high speed fan doesn't kick on I believe that means the blower motor resistor is bad.
lito
Caracas, Venezuela
The a/c will only start the low speed, to test the high speed you should power the relay by hand or have a test tune for it.
the thing is that once it starts the LS it won't reach the activating temp for the HS.
danbogart
Can't you change fan speed with your sct?
Sent from my DROID RAZR using Tapatalk 2
Max ac will. This is how I tested my different fans on a many ocasions. Let the car warm up till the low speed fan comes on. Then turn on max ac and hit the recirculation button. With in 30 secs to a min the fan will kick on high and stay on high till you turn max ac off.
How do you test the fans to make sure both speeds are working?
See above.
No you can change temps for speeds though.
