Compression is key. First off, I'd go with the JDM 302E over the Brenspeed 302. The JDM is aluminum versus iron block in the Brenspeed which is 65 lbs you don't need on the nose of the car. Not sure on the Brenspeed specs but the JDM uses a Kellogg crank rather than an Eagle (Chinese) crank. Research it and you'll see the Kellogg is much higher quality and you can safely push it further.While reading through this, one thing popped out that has to had to the difference: compression ratio. The higher CR on coyote contributes to more power (in addition to the head flow). As such, what happens when you both stroke a 4.6 to 5.0 AND increase CR to around 11 or so? THEN how similar are they?
RE: to the above post, unless you can get the r/a for cheap, it'd be difficult to do a forged build for under $2500-3000. Shop around, look for deals, take your time, and pick up hat you can find at decent prices, and then you stand a chance!
(I'm one of those forged/stroked guys, with a 5.0L stroker 3v, pushing over 700 crank on pump gas at 18 psi. It all fits nicely within the 4.6 setup)
I've read a lot of what Bruceh has to say. His builds are awesome and I'm sure he will say something soon. He has said for a cheap build use stock crank, boss rods less than 200 from tasca and forged pistons. You could also go with the boss block 1100 from tasca and still use stock crank, boss rods and big bore pistons. It would be a little more but then you have 302cu in.
Lots of great information in here, thanks to all who are providing it! To be clear though, I don't have a hard on for stroking (no pun intended) lol, I'm just trying to find out what all options are out there. If I can build it relatively inexpensive and get the compression up and HP over 600 RWHP then that will likely be what I do but I'm not ruling out any particular options just yet.
600hp is not inexpensive no matter how you get there. By the time you get done with the engine, transmission, drivetrain, fuel system, suspension, tires and brakes to handle 600hp it's not a cheap investment. If you want inexpensive then you need to scale back your wish list a bit. 500hp is inexpensive, 600hp is not.
Well, that makes me a little happier then! I like the fact that my car is a 2008 and i'm not afraid to get in and do things to it for fear of voiding the warranty (since it no longer has one). I'm pushing about 500 right now but plan on forging the bottom end or going with a forged shortblock. I guess now the only thing is to decide if I want a stroker or to just bore it a bit and go non-stroker. I plan to push around 15 pounds of boost because I hear that much more than that is when you want to start going with race gas and such because the other gets too unstable.
Any quick opinions on stroker vs non stroker? I guess if I went non-stroker that I could likely re-use my current crank if I wanted to save money since it's rumored they're good for around 700 or so horsepower. I guess the rods/pistons are the weak links.
I don't understand why everyone has such a hard on for stroking these motors, especially people with FI. It just doesn't make any sense to me...
another thing, what is the average boosted and forged/built 3v RWHP RWTQ ceiling in any/all boost combinations/ any compression ratio but using 93 octane only.
reason being, if say 750rwhp or so is the average 93 octane can produce or has been seen, then all youd ever *need* is a "thousand horsepower" capable block. custom built or vendor shortblock. if that's the case the boss rods are a no brainer!
FYI Manley rates their h beams at 700 hp. Not rwhp. The boss rods are beefier than stock but there is no way they are as strong as a hbeam with arp2000 bolts.
What are people pushing the boss rods to? Here's a pic of a generic h beam next to a boss rod. Just as a guesstimation I'd think the boss rods could handle as much as a gt500 stock rod. The reason I say that is because they look very similar, are made the same way with the same material, and the boss rods should be stronger due to being shorter.
If you have a 700hp coyote and you have a 700hp 4.6...
***** you have a 700hp car what are you bitching about?
I suspect darrenism, just sayin'![]()
