lethe
V4g!n@ #er
Regardless of what total seal said i would still replace the rings.
I thought I had read that you don't want gapless rings in a mod motor and I dug up an old thread with that. Especially one that is boosted.
http://s197forum.com/forum/showthread.php?p=514476&highlight="gapless+rings"#post514476
So I just got done with cylinders 1 thru 4... sigh
Spark plug #1
Spark plug #2
Spark plug #3
Spark plug #4
Spark plugs 1 thru 4
Cylinder #1 valves
Piston #1
Cylinder #2
Piston #2
Cylinder #3 - valves open
Piston #3
Cylinder #4 - valves open
Piston #4 - TDC
So obviously its the heads...question is, will a valve guide/seal do the trick or is there more to this than just the seals?
Interesting... Not sure.
I will let you know upon tear down...actually you'll see them when you come over and help. lol
Ummm....is JDM not assisting you in any way with this?
Jdm rings are just total seal rings rebadged
Sent from my GT-I9100 using Tapatalk
Gerald,
I was looking at these pics and the valve stems appear to be ground down near the head. Stock valves don't look like that. At least that's how it appears in your photos. Am I seeing that or is it just an optical illusion?
The valve stems aren't ground, that is how stock valves look. This is the way I have seen ever 3V production valve come from Ford.
Here is a picture of a set we removed from a customers head before sending them out to be ported and replaced with Manley valves.
I have some stock valves in front of me to compare with. I can see what the normal taper looks like. What I was specifically talking about is this pic. It could very well be the picture quality or my eyes but to me the stem looks rough and tapered near the head.
They offered to work with me if I sent them the motor.
I figure the cost of shipping the motor and back, the amount of time, and cost it will take, I'm better off doing it myself. Unfortunately, I'm 3,000 miles away.
That's obvious, before I bought them I actually talked to total seal about them and even they said they were a good ring, they never said better, but they definitely didn't try to knock them.
