Guys, Mike@HSW posted this on another forum a while back but just browsing through some of the pages here, bottle pressure seems to be a subject of question. Please don't think of this as a giant sales pitch because its not. We at HSW believe in informed nitrous use and helping people understand what exactly the 'ins and outs' of nitrous really are. Bottle pressure affects every nitrous kit equally and the end user should really follow his/her mfg's suggestions for bottle pressure and jetting accordingly. Hopefully this answers some questions and maybe helps some adamant non-nitrous users think twice
The first thing we have to understand is the temperature/pressure relationship. Take a look at this graph I quickly threw together below of which we’ve all seen before. This shows the relationship of temperature and pressure (k=P/T). Pressure (P) of any substance, more specifically nitrous, is in direct proportion with temperature (T) when pressurized in a contained vessel. As we increase the temperature of the bottle, we see a direct result on pressure in the same direction. The continued vaporization of the liquid nitrous is a direct result from the increased temperature/pressure relationship and can be coined self-maintained pressure regulation. As the temperature increases the liquid expands, meaning it becomes less dense. I also have attached a graph showing the density of nitrous oxide at certain temperatures. As you can see from the first graph, the higher the temperature, the higher the vapor pressure levels. This causes the liquid to expand and vaporize, therefore decreasing the density of the substance. How does this affect you? In using nitrous oxide you want to keep the nitrous oxide in liquid form, dense and cool. This is why keeping line length on direct ports to a minimum is also important. Engine temperatures can heat soak the lines and raise the nitrous above its critical temperature before it exits the nozzle. This we do not want, phase change should occur in the runner, not in the nitrous lines. Think of heating water from liquid form to vapor. A cubic foot of water vapor is fractions of the weight of a cubic foot of liquid water. Same principal with nitrous oxide, it just does it at different temperatures and pressures. Taking it one step further, lets not negate the cooling effects of nitrous in an intake manifold…and what do we know about cooler air? More dense, is it not? So yet another indirect advantage to getting the nitrous charge as dense as possible.
The critical pressure of Nitrous Oxide is 1069psi. This is the upper most pressure required to keep Nitrous Oxide in the liquid phase and anything beyond that is not necessary. Taking it a step further, any substance which goes beyond its critical pressure and critical temperature (critical point) becomes supercritical. Matter can occur in three states, Liquid, Gas and Solid. When liquid Nitrous Oxide reaches supercritical (>1069psi and 97.7F) it becomes neither a liquid nor gas, but actually takes on characteristics of both. Some believe it resembles foam and as you can imagine this changes its velocity through the main feed line as well as any consistency in mass flow. It also results in a premature phase change into a gaseous form before it ejects from the nozzle. As was stated earlier this is not what we want. We want nitrous to remain in liquid form until it enters the intake. Now above we spoke about self-maintained pressure regulation in the bottle. While 1069 psi is at the brink of becoming supercritical, it does not mean that it’s the ideal bottle pressure. Looking back, besides the poor density, it would take a lot more time and energy for the bottle to regulate itself back to the 1069 launch pressure. Something of which we certainly do not have time for, nor do we want to waste any energy (in multiple forms) on doing so. Self-maintenance of bottle vapor pressure is quicker and more efficient when done at lower launch pressures without negating velocity. We jet our systems to 950PSI. This is ideal for both maintaining bottle pressure through the run as well as keeping a nice dense charge with great velocity.
Another thing that must be taken into account, the higher the bottle pressure, the larger range of pressure drop we will see. On smaller shots a large drop is not going to be an issue. When going beyond 200hp you will begin to see bottle pressures decreasing during a run. Again, this is not what we want. The name of the game is consistency and declining bottle pressure will affect your tune up. Therefor, our end goal is to regulate a target pressure not just at the launch, but through out the run as well.
Nick
Nick
