lostsoul
2014 vett or 2015 stang..
It would still be pretty easy to void the powertrain warranty imo. A motor tuned with added spark timing, modified wot lambda, vct changed to hold more compression, and modified knock sensor tables detonates a piston causing catastrophic failure. It would be hard to prove that was a fault of Ford.
normally yes, but how do you tell one guy with a tune that we wont fix your car even though there are stock ones having the exact same problem.. now if it were different pistons getting hosed then I think they could skip by it.. but the same one over and over.. remember, in the long run Ford has to prove it was the tune. In front of a judge looking at the same issue with tuned and non tune cars I think tie will go to the runner(customer). Challenging Ford for something that cost a few hundred or a thousand might be a big waste of time.. but for 7K and up.. we might see some lawsuits..
and I will be sitting in my 3v eating
