From the images in his post, it appears the PCV system is still fully active connected to an oil separator/catch can. Unless his catch can is a breathable type? It doesn't appear he's running any type of an open, breather setup on his Coyote. Unless I somehow overlooked something? he just wants to replace his Coyote's cam cover and intake manifold ports with AN fittings just as his catch can has along with adding an inline check valve as a direct replacement for his Coyote's PCV valve, but yet would still function much in the very same way while also keeping the factory PCV system fully active.
