Pinion bearing question
fish337
Myerstown,PA
Can you put the SVT pinion bearing kit Ford Racing M-4210-B1 in a Gt rear, also I am adding the carbon fiber discs. Thanks
Genius
Goodrich IL
Yes you can!
Just make sure you use the thick shim behind the race,
then set your depth from there.
The standard GT kit is cheaper and has been working for years.....
Gene
fish337
Myerstown,PA
So you do you think I should use the standard GT bearings or the SVT ones, I have 450 rwhp, and run it on the strip at 4-5 races a season.
Thanks
Genius
Goodrich IL
I'd rather not make that call for you.
Either way the main thing is a good gear set up!
A well built 8.8 can handle twice your hp.
I always tend to over do things myself, if the
B1 kit makes you feel better go for it...another $50?
Gene
