Planning For Forged Interal Build @ Fastlane, Help With Questions:
2to3threE
Banned
10$ sez :bs:
You have until Feb 28...
lol, i am i am just worried about the input shaft and axles holding up. i think with 5.0 and 2.8 pulley which is 15 psi, i will be in the 580 rwhp range....maybe a bit more.
Pike2244
Just starting a similar build as well so I am watching this thread to see where it goes... So did you go w/ the $4k Alum. big bore???
2to3threE
Banned
Doing a 26 spline input shaft for the tranny or what?
where do i buy that at? also does that require me to get a 26 spline flywheel and clutch?
if so i am probably looking at like a grand just for that stuff alone.
ILW84U
Edmonton, Alberta
Liberty or Promotion. Yes & yes. When I did my build I was looking at this & decided it was not worth putting that kind of $ into a 3650. Unless you know how to tear a transmission apart, it is not a DIY. I was leaning towards a TR6060 when a great deal came up on a 4R70W that I couldn't pass up & haven't looked back.
2to3threE
Banned
well i think my shop would have done it, but what websites sell that stuff?
ryanralston07
Dalton, GA
so pretty much nobody sells these 26 splines straight out?
IIRC you sent in the 10-spline shaft and they cut the shaft and weld on a 26 spline piece (talking about Liberty)? Yes you will also need a new clutch. Just have the stock flywheel resurfaced and save some $.
2to3threE
Banned
whats the tr6060 tranny a 10 spline? also one of those would require a different cpu right?
2to3threE
Banned
TR6060 has a 26 spline shaft
so 2 questions, if i get a tr6060 tranny and i want to buy a new clutch and flywheel, i have to buy one that is for GT500 right? and same with flywheel?
do i need to have my tuner adjust my current tune, for the tranny?
ryanralston07
Dalton, GA
just a new clutch, but most will say to buy a new flywheel too. I'd just have the stock one resurfaced, unless you want to go aluminum for flywheel (stock is steel). You can buy a clutch that is 26 spline to work with the tranny and there shouldn't be any tuning unless you are going from auto to manual and I don't think you are...
2to3threE
Banned
so any gt500 clutch is 26 spline? also i will need a new pinion flang, and pinion as well as driveshaft right?
19COBRA93
Ford Racing
Clinton, Ut
Yes & yes.
just a new clutch, --- You can buy a clutch that is 26 spline to work with the tranny
How many times do you have to ask the same question and get the same answer?
YES, the GT500 transmission is a 26 spline which also obviously requires a 26 spline clutch. The flywheel doesn't give a shit what spline the clutch is.
Here are your options:
-Run an actual production GT500 clutch which is a dual disc clutch/flywheel assembly.
-Use your stock flywheel (resurfaced) and pressure plate and use a 26 spline clutch disc (Centerforce, or FRPP sells these separate).
-Run your stock flywheel with an aftermarket clutch assembly with a 26 spline disc.
-Buy a new flywheel of your choice, and a clutch of your choice with a 26 spline disc.
That should answer your question regarding 26 spline anything.
2to3threE
Banned
good to know, im probably better off not reusing the stock pressure plate though right?
bmaxwell
BÆST
ATX
So it's mid january... How is this build coming along?? You still have a month and 10 days to complete it lol
