Does the motor turn over now since you removed all of the plugs?
No it does not, as coolant is likely what caused the bearing failure. It is still seized.
Hey Ron, if you need a machine shop let me know. I can pressure test the block/heads for cracks, bore/hone, deck the block/heads, oring the block and also machine the rear thrust to allow a full thrust bearing and machine the thrust bearing for better oiling. It would require to drill the bulkhead of the block to allow oil pressure at the back face of the crank. The block will have to be machined to accept a full thrust bearing. You will need to get 2 sets of main bearings though, unless you can get them to sell two lower thrust bearings, and we might have the other mains in stock.
Bring the block down assembled and I can check the end play for you and bearing clearances if you dont feel comfortable.
Too bad your so far away, id help pull the motor out. It would be easy too, i have a crane on my work truck.
Real class act...btw where do u work.
its covered in a lot of dust?
nothing new. i have no help to pull the motor, nor am i even sure the best way to do it, so it sits
