zexystang2
Well thats good to know. Because im wanthing to try 10 degree lockouts since im having vct problems on the passenger side.A 6766 is not a huge turbo, making that boost on a perfectly flowing engine won't be that easy, if by some reason the engine is not moving air correctly boost will raise as it is more a measure of restriction than anything else. A locked cam will not cut your HP by that much, actually I've tuned quite some locked at zero retard cams without any issues.
Paul (againstallodds1) has stock cams locked at zero and ran mid 9s with a 76mm that comes with the hellion kit.
