06gtmustang
So will this work? Can I run a hose from passenger and driver side into each port and that be ok?
Yup that will work.
Yea, if you look in my album here there is a pic of how small the side is before you remove the pcv valve.Unless you take out the valve, the drivers side is pretty much useless. I run just straight breathers with and oil cap filter too. I've changed out the passenger filter and oil cap filter a few times but never touch the driver's side one. Running an oil cap breather helps with any oil drippage because it gives it another spot to vent from and you don't have as much going through the one tiny filter.
