Yeah, I haven't even considered the TH350. Not much of a weight advantage so might as well go 400, right?
do you loose the e brake with the strange brakes?
I will post some up next weekend. The main factor is what wheel we are talking about. There is another thread on here where a member fit a 18X11 wheel---as the wheel is large enough in diameter to where the shock and bumper stop purch is not an issue. But for a 15 inch wheel with a slick, definitely an issue.
So if you are looking for ideas on clearance for a 15 inch wheel, I can help.
I am worried about a 15" wheel. Also where are my pics??? When you plan on getting the headers done?
I am looking at getting a 15x12 Bogart and would like the extra room. I am already talking with guy that is doing the cage to move the shocks in bound when he builds the cage and might go with an in bound coil over kit.
You can fit an 11" slick.
That and the LCA---even with some offset bushings, it looks as though you can only go so far in without changing the LCA mounting point.
I went inboard with the shocks as I wanted to run double adjustable Strange drag shocks and coil overs. Coil overs in the stock shock location effects wheel / tire clearance.
In any case, the motor mounts and trans mounts are done, the headers are being done right now, here is a picture of the drivers side:
nice Paul!
Painters tape a the headers? just for mock up I assume?
nice Paul!
Cool!Yeah, that tape was over all the exhaust ports while the headers were being fabricated. I am going to remove when I take the headers back out this weekend to paint. The tubes are individual once you take the collectors off, which makes installation and removal so much easier.
