Midlife Crises
My first guess is those gears are set up too tight. The gear mesh whine rises and lowers with speed, under load or coasting.
Sounds about right.Just to clarify, just moving the original shim is by no means the correct way to swap gears. It is a shortcut that saves time doing the job and works well MOST of the time. But not always.
The pinion shim is there for adjusting for case/housing machining tolerances. You add or subtract the scribed number on the new pinion and old pinion. If you want it to be dead on. I personally find that a few thousands plus or minus from ideal pinion depth causes no issues. As long as the tooth contact pattern and backlash can be set by shimming the carrier.
This approach has worked for me.
