Rear lca recommendations
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
I did the Steeda spherical bearing on the axle housing after tearing my stock bushing up. I have it paired with a BMR adjustable upper with a poly bushing at the chassis side and Steeda Chromoly lowers with whatever bushings they come with from Steeda-they market their bushings as exclusive to them and they are more compliant than the bushing in my BMR UCA or my BMR sway bar.
The rear of the car does feel more like it can rotate more freely, and not hitting that point where everything goes stiff due to bind at the speeds that I am comfortable with in a corner. But more importantly for me, the car goes straight at the dragstrip.
Juice
Im good now, that search reminded me of one reason I chose to keep OEM LCAs.
DieHarder
In an effort to avoid the bind issue I opted for J&M UCA. It appeared to offer the best compromise and I've found the car does rather well dealing with any kind of on/off roll center handling issues. The quality of the part has also been excellent and I changed out the rubber in the axle housing with poly. Still quiet and handles very well.
https://hotpart.com/product/05-10-m...-control-arm-red-jm-products-made-in-the-usa/
Midlife Crises
Fairbanks, Alaska
Is it OK to lube the poly bushings with this stuff?
Most poly bushing manufactures recommend silicone based grease. Other greases containing petroleum can cause the bushing to crack and come apart. Many marine greases are lithium and or moly mixed with petroleum and I avoid them around polymers.
Racer47
Doesn't have much to say
SE Wis
Enfield
Shenandoah Valley
The spherical rod ends in my new rear lower control arms click and clank a bit going over bumps and such. Somewhere I have read that there are dust boots available to encircle the rod ends. These not only contribute to longer wear, but they also muffle the noise quite a bit.
Trouble is, all my searches for these boots have come up empty. Can anyone help?
tia, Enfield [not upgrading for a while; just enjoying the ride!]
Pentalab
Did you notice an increase in NVH when you installed the steeda spherical bearing at the axle end of the UCA ??
Norm Peterson
corner barstool sitter
RIP - You will be missed
Something like these?
RACE BOOTS Heim Joint rubber dust boot, CFR.625,works with 5/8" -1 pack of 4pcs | eBay
Norm
RED09GT
There was some difference in sound, almost like a slight pitch change to the gear noise. I can't feel any change vibration wise and it probably improved in the harshness department as it allows more articulation.
