Rear lca recommendations
Discussion in 'Mustang Chit Chat' started by Enfield, Apr 8, 2021.
  1. RED09GT
    RED09GT Equal Opportunity Offender S197 Team Member
    2,428
    382
    I did the Steeda spherical bearing on the axle housing after tearing my stock bushing up. I have it paired with a BMR adjustable upper with a poly bushing at the chassis side and Steeda Chromoly lowers with whatever bushings they come with from Steeda-they market their bushings as exclusive to them and they are more compliant than the bushing in my BMR UCA or my BMR sway bar.
    The rear of the car does feel more like it can rotate more freely, and not hitting that point where everything goes stiff due to bind at the speeds that I am comfortable with in a corner. But more importantly for me, the car goes straight at the dragstrip.
  2. Juice
    Juice forum member
    2,441
    712
    Im good now, that search reminded me of one reason I chose to keep OEM LCAs.
  3. DieHarder
    DieHarder Member
    388
    184
    In an effort to avoid the bind issue I opted for J&M UCA. It appeared to offer the best compromise and I've found the car does rather well dealing with any kind of on/off roll center handling issues. The quality of the part has also been excellent and I changed out the rubber in the axle housing with poly. Still quiet and handles very well.
    https://hotpart.com/product/05-10-m...-control-arm-red-jm-products-made-in-the-usa/
  4. Enfield
    Enfield Member
    94
    18
  5. 06 T-RED S/C GT
    06 T-RED S/C GT forum member
    62
    2,209
    332
    As long as it's either synthetic or marine grade, yes!
  6. Midlife Crises
    Midlife Crises Senior Member
    921
    552
    Most poly bushing manufactures recommend silicone based grease. Other greases containing petroleum can cause the bushing to crack and come apart. Many marine greases are lithium and or moly mixed with petroleum and I avoid them around polymers.
  7. Racer47
    Racer47 Doesn't have much to say S197 Team Member
    921
    196
    Midlife Crises likes this.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
