Redfireshaker06
Joedls, what roushcharger are you running to be in the 11's? I know a 35 show is not helping you that much
I'm in the mid 11's with the M90 and I still have stock stall and converter so it is possible!Damn, i'm on the fence right now to either buy an Chrome Roush M90 or buy an Edelbrock TVS. I don't plan on swapping out to a forged block but would like to try to get the car into the 11's. Jim at JDM thinks that he could get me there with the M90 with the stage 4 upgrade kit and some other bolt-on's and definately with the TVS. I dunno if I want to spend the extra on the TVS if i'm not going to go with the forged internals? Decisions........
Who tuned your car? Right now, i have 4.10's and a TCI 3000 stall convertor,a long with a JLT II CAI and Brenspeed Tune. I will sell the JLT as I won't be able to use it with the M90. I think i am prolly going with the M90 as i can't pass up the deal I am getting on it.I'm in the mid 11's with the M90 and I still have stock stall and converter so it is possible!
I put down 415rwhp but I think the dyno was reading low cause my 1/4 mile time says otherwiseWhats your power #'s?
Blow By Racing did a custom dyno tune. The shop temps at Blow By were from 90 to 100*F the day of the dyno. I am sure that had something to do with the my numbers being low. Going do some data logging within the next 2 weeks to check a few things. I will report what my numbers are with this cooler airWho tuned your car? Right now, i have 4.10's and a TCI 3000 stall convertor,a long with a JLT II CAI and Brenspeed Tune. I will sell the JLT as I won't be able to use it with the M90. I think i am prolly going with the M90 as i can't pass up the deal I am getting on it.
Thanks Carmen! I will be installing a True Trac diff and a PTC converter within the next two weeks then I think I will be done for the winter. Time to make some 1/4 mile passes in the cold then pull the engine at the end of winter. Still trying to figure out what route I wanna go.I would think you are pretty close to what I am based on your mods. I just received my Innovators West 10% overdrive crank pulley today. Once installed and re-tuned, I'll be at the limit, for me anyways.
Although your car may make less power due to the hot weather, the correction factor should take that into account when calculating your power level on the dyno.
Regardless of what the dyno shows, your car is Bad-ass fast.
