S&H Stealth Single Turbo kit 05-10
Moar pics of the mock up.
Bobby
turbo gt about to go fast
No need to lift the motor or use a different k member just to run this kit. All you do is slide it up in there and put the couplings and clamps on it. Also if you have an aftermarket k member you can use this kit with no problems.
W3bb3r04
Slow 3v Member
Clinton, TN
Do you know if the 2013 GT500 oil pan will clear on the side where the cold side goes to the intercooler
Sent from my HTC6525LVW using Tapatalk
Bobby
Not sure but i am sure you will tell us. If it hits we will fix it. But i am sure it will clear. The pipes angle towards the out side a little all the way to the intercooler then turn back. The bov sits almost under the washer fluid resivor.
roberts
Bonne Terre, Missouri
man this kit looks alot eaiser to instal than the old kits. looks like way less clamps. witch means less of a chance of leaks. I want to do this kit so bad. ony if i could sell my 0n3 kit but then i have to find someone to buy the comp turbo i havent used yet. or would they take it back?
Its 3" piping from turbo to intercooler and then 3.5" piping from intercooler to throttle body so this bitch is going to move some air!
And we tried to keep connections to a minimum, kit only used one vband for the header merge pre turbo and one after for downpipe, also kept silicone couplers down to as few as feasible and still make it easy to install the sections of pipe.
If its a CT4 T4 oil-less your turbo will fit this kit.
Yeah it would take some work and an oil scavenging pump to work in a low mount setup. These stealth kits are deisgned for oil-less turbos, all the benefits of a low mount without any of the side effects.
roberts
I'm not going to do eBay. I got it on Craigslist and svt just haven't put it on here yet cause there is 2 other kits that hasn't sold yet
The redesigned intercooler/radiator support brace is done! Now our kits can be run with or without a sway bar! We went to a thicker gauge and larger tube dom steel, boxed the sway bar mounts and added a support gusset for increased strength while still dropping weight over the stock unit! It is now standard in the single and twin kits! Will come standard powder coated black, but as always we can do a custom color when you order. Check it out!
Shotokan1509
CT
:clap:
Bobby
Here is a pic of it on the car. After getting it on the car he saw he needed to lower the sway bay just a little to make it easier to get the oil filter iff so he is doing that now but you can see how it works. It looks bad ass
converturbo
Cedar Park, Tx
I spoke with Jeremy via email last night about a kit. After seeing this I am even more interested. Keep up the good work guys. I hope to be doing business with you in the next few months.
