01svtL
I'm looking at picking up an 08 Sport Trac limited w/ the 3V 4.6 V8. Does anyone know how similar the motor is to the Mustang, if not exactly the same? I'm wondering if the compression is lowered at all. I've also heard the upper intake manifold was different, but this is coming from guys that care more about offroad tires than they do horsepower. I've owned several 12 second Lightnings and a low 12 second Mach 1, so these 3V's are completely new to me. In stock form, the 4.6 Sport Trac is rated at 292 hp and 325 torque (I think). I'm guessing the single exhaust to keep it quiet ("luxurious") and a slight detuning is what brings it down from the 315 hp that you guys are running stock (IIRC).
Anyway, I'm looking to get the motor to breathe a little better with some exhaust work, get a set of 4.30's (the few that have done it have actually reported a slight INCREASE in mpg), and a good tune. I'm thinking if the motors are the same, it should also benefit from a throttle body and whatever other mods you 3V guys run the most. I haven't begun to read up yet, as I just joined, but I will be shortly.
So anyway, if any of you have any knowledge on the subject, fire away!
i call shinnanigans on that as well.
