Separation plate issue?
1bad65
Austin, Tx
My car is making a noise that appears to be a separator plate issue. I'm curious, has anyone here had that problem and how did it happen? Ie, did it do it from the day you bought the car, or did it just suddenly start making noise? Mine has 75k miles on it and it's ran flawlessly so far, but this noise started suddenly. It also started right after I had my cams installed. Could the extra power have caused an issue with the separator plate?
dysan
Dis-Member
Williamstown, N.J.
I suspect he's talking about the plate between the transmission and the engine block. Mine rattled from early on when I owned it and I just bent it a little and stuck some left over rc car silicone hose in the area where it was rattling to stop it.
As for making noise after cams, some people get rattling from their clutch when cams are put in but usually when they are lopey ones and I believe it's generally people with twin disk clutches.
Ah, the dust shield on the bellhousing. I have an 07 and mine started rattling at 25k miles about 2 months after installing the 127300 cams.
I also undid the bottom bolts and put some black rtv between the plate and the trans and bolted it backed down, completely fixed it.
1bad65
Austin, Tx
I should have said separator plate. My bad. And my cams are 127300 cams.
AnotherS197GT
Serial Valve Dropper
USA
If it sounds like its knocking its the TOB. If its a buzz or a rattle, its probably the plate.
tmcolegr
It's All About the Build
Central, FL
what do you mean???
You can't access the thread from the link I posted or open the attachment in the thread
1bad65
Austin, Tx
I got it now. It was opening in a new window and for some reason I wasn't logged in on that new window. Thanks.
mustangflanagan
south jersey
the dust shield on the bellhousing is it between the tranny and bellhousing or is it between the bellhousing and engine? Because i am getting some really nice rattle when i get on the car a bit and then the rattle dies off but doesnt do it when accelerating normally
mustangflanagan
south jersey
TRYING TO TRACK DOWN A RATTLE.
hERE IS THE DRIVERS SIDE OF THE h PIPE IS THAT A EXHAUST LEAK.
hERE IS THE DRIVERS SIDE HEAT SHIELD BY THE h PIPE
hERE IS THE PASSENGER SIDE HEAT SHIELD.
tHINK ITS A EXHAUST LEAK BECAUSE IT ONLY RATTLES WHEN I GET ON THE CAR?
ctt326
Brenspeed Hater
Fort Wayne, IN
My separator plate just randomly started to buzz one day. It would do it on a cold start up and also around 3k rpm if I remember correctly. There are already a few threads on this, and the diy fix is easy.
ctt326
Brenspeed Hater
Fort Wayne, IN
Yeah that is obviously a pretty serious leak if it has left that much carbon on your heat shield. Idk, looks like you need to push the midpipes back if you can and try to center that clamp.
mustangflanagan
south jersey
it will not move any further back at least with the over axle pipes stil bolted to the mufflers i guess i will give that a try. Keep in mind the H pipe is a summit cheapo.
