Dark_horse
Ok so as many of you know I have had some issues with my build on many levels. I have taken a break from deer season and jerky factory that has been my kitchen lol..
The latest issue was that my car was not going into gear while it was running...
Stock clutch, new slave and spec 2 billet steel flywheel (8bolt)....
So here is a video of the slave moving and engaging the fingers on the pressure plate... does it look like it is moving far enough?
I have called spec and they said the stock clutch will work with that flywheel without any issues... the reason for stock clutch was just to break in the motor, gears and just crusie around for the rest of the season....
Since the season is over and winter is pretty much here
I went ahead and dropped the tranny, pulled the clutch and flywheel... Im going to order a spec stage 3 clutch since they are like 360 bucks on their website and rock it for awhile.
soo techies what are your thoughts??
