UltraKla$$ic
PERENNIAL WAXXER
I can give you my number if you run into problems. THis is cake if you pay attention.
Well....with my V2 I made 430 with stock cams, Kooks LT's, CMD plugs, BBK TB, catted H and I think that it is it.
You will be over 400 with any FI, even the almighty baby blower, the M90-that's for you Nick-so if you want to stay away from 400 don't go FI.
On the flip side you will be hard pressed to get close to 400 hp NA even with heads.
Keep in mind about the heads that the bang for the buck is not cost efficient; by the time you purhcase the heads, get all the stuff needed for a head swap, install the heads and adjust the tune you will gain approx 20-25 hp; bolt on a form of FI and you will bolt on 100+ for close to the same price....I know because I looked into going all out NA until I did some research and others pointed out the hp vs $$ deficiency staying NA was.
Can I ask what the self imposed 400 hp limit is about?
You WILL NOT make safe power on 87 octane with boost. Just not happening, plan on running 93 bud.A couple reasons.
1. I know it will be more than fast enough to wipe the floor with most of what is out there, on the RARE occasions that it matters.
2. I know its plenty to get me deep enough into the 12s on drag radials, which is where I want to be, and even on 285 556s I will be in the 12s.
3. Self control. I have some of it. Not enough of it. Its a low enough number to keep myself in check somewhat.
4. Reliability. I know these motors are fine even at 450, but its even safer at 400. I also know I can tune it on 87 and be there if I go FI. Ill just pull timing back and keep boost low and it will be happier than a pig in shit.
And I just dont care anymore. Like I have said in the past, I had a 500whp rocketship. 500whp with AWD is a completely different animal than what 500whp RWD is like on the street. Because it hooks so much more, you accelerate so much faster (till about 70) (although I had wheelspin in 4th from a roll on my big boost map) I dont need that, I dont want it. I also know what 500whp feels like on any street tire, and I have no desire to plant myself backwards into a tree, which, while I am a very good driver and almost always drive like an old man, there are those times when you STAND on it, and 500whp can lose it in a very bad unrecoverable way a lot easier than 400whp can. I dont care about being that fast anymore, I just sort of feel like that part of my life is over and behind me.
Honestly, 400 is sort of an arbitrary goal, and a more solid limit. I dont think I need 400 to be satisfied and happy with the performance. I am already almost happy with it, and I dont have my LTs installed yet, I dont have the cams in yet. I am looking at what? 40+whp with those 2 things? There is a decent chance I will do them, and be fine with it. If not, its going to be close enough to where the heads will get me there.
Also, I really like the idea of having all the restrictions gone. And if I get a wild hair up my ass for more power, well think about what the basic vortech kit on top of the heads/cams/intake manifold/TB/LTs would do. I know, again, not a FI optimized cam, but that non intercooled vortech at low boost, would put down plenty for all but the most power hungry.
To be realistic, I know how I think, and even if I said fuck it, scrapped the cams for now, magically found the money for a TVS, I would STILL obsess about getting the lumpy idle, and not having ported heads.
Why am I so obsessed with the idea of heads/cams? (besides the lumpy idle) Hell man, why do any of us obsess pointlessly about anything. I just WANT it. Even if its a bit pointless. The way I look at it, if I can do the cams, then I can do a head swap, since the only additional thing I would need to worry about would be timing the motor, which isnt difficult. And the FRPP heads are about 1900-2000 including the bolts/gaskets (1750ish for the heads, plus whatever the gasket/bolt kit cost is) which is still well below the basic vortech kit. So its not like its an amazingly huge expenditure. Is it the best bang for the buck? No, its 20 or so whp for 2000 bucks. But when you are approaching a ceiling on the power (even if its self imposed) and you are an obsessive compulsive mental basket case that has some burning NEED to have every path air touches improved, you are left with no choice.
For real, I am not OCD, but I am Bi-Polar II which brings some OCD tendencies to the table, so I have given up any real hope of NOT doing the heads, even though I keep trying to convince myself I will be happy with the power level. (which I will probably be, but even if I AM happy with the power level without them, I will still almost definitely be obsessing over them)
if you could run out of breath typing, I would do it on a regular basis
If a setup can do say 450 on 93 it can do 400 on a lot less. Pull the timing and it should be fine. 50whp may not be the difference from 93 to 87 though... Maybe 89. I know on 350ish hp 4 cyl turbos, the difference between 91 and 93 is about 20whp, so I dont think a 50whp drop to go to 87 is unreasonable to expect.
In the end, what octane you run, is irrelevant in terms of the power being safe or not. The tune is what makes it safe or not. You tune the engine to the conditions it will be operating under, Altitude, octane, etc. So tuning it on 87 is no less safe than 93. You just cant tune it for as much power on 87 as you can on 93. So if a car could do, like I said, 450ish on 93, I am betting tuning it on 87 would land you right around 400.
And dont fucking talk down to me with that "bud" shit. I have been tuning cars for a long fucking time and although I may be a relative newbie to the mechanical specifics of the modular ford motor, EFI is EFI, and the principles although differing slightly, are essentially the same.
91 is available in those areas who dont have 93. There is no reason to run 87 octane, especially if you are FI. Just a bad idea.^^^^^Pretty sure some areas don't even have 93 octane.
And that was not being condescending, bud is a friendly term. If I was being condescending I wouldve said "plan on running 93 dumbfuck"
Dave, I've done a couple cam swaps using heater hose as a wedge. Torqued the cap caps down to 89 inch-pounds per spec; and torqued NEW ttl cam sprocket bolts per specs as well.
Dont use a screwdriver with tape or rag; pieces can get torn off and left behind, or come loose altogether.
