So I have Hot Rods on the way, and I have a helper lined up that has done SPR cams before. He used the wedge and compressor, but he had borrowed them, so he doesnt have them.
I really dont want to spend the money to rent them from Freedom, as that would really eat into my budget, if I dont HAVE to.
I have read posts where a lot of people have said you dont need the compressor. I know I can wedge the chain with some hose or whatever I can stuff down in there that wont move (I am thinking maybe a LONG screwdriver with a rag taped around it), and I will have the guy helping me hold the gear up, and the gear/chain will be marked.
SO, I have a few questions.
Do I still need to line the crank up the way it says in the instructions?
--- I would assume I would, right?
How do I go about getting the cam out, without the spring compressor?
Do I just slowly back all the bearing cap bolts out a couple turns each at a time till the tension is released?
Will the tension fully release before the bolts are all the way out? Or is the cam gonna pop up and out possibly damaging threads/whatever?
If there is tension even with the bolts almost completely backed out, how do I get the cam down in enough to start the bolts?
