SSP's 900+RWHP Turbo Streetcar
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
No screwing around with this TH400. Since it wasn't what it was supposed to be and we had to buy some hard parts I splurged and ordered $2,500 worth of some nasty 2k HP billet parts and Alum drums that will remove over 8lbs of rotating mass! Worth a few hp and over 1tenth in 1/8th mile alone.
roberts
Bonne Terre, Missouri
im getting ready to put a order in with summit to get all I want beside trans, ds and converter. Where u get those th400 parts and and the 8lbs losing would be nice. Also what shifter is that is it ratchet as im thinking about getting a ratchet shifter. what u think about those or why did u get the tci one?
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
I ordered a lot of the parts like the pro-mod alum intermediate drum from TSI(transmission specialties) the 7075 alum front drum with billet alloy input is from Coan transmissions. ATI makes some nice billet drums as well.
I prefer pistol grip shifters. I have used the Hurst Quarter Stick many times and it is very close to the TCI Outlaw but I wanted the black handles to match my interior better.
roberts
cool deal thanks man!! Im going to do a th400 instead of a 4r. Ill be watching this to see how it all goes for you!!
SStang
I may of missed the reason, but why are going with th400?
Thanks.
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
And cause its stronger and cheaper than a 4r!
But anyway how u going to get you mph gauge to work?
Early 90's 1-ton trucks had elec speedo th400's
I am using a factory speed sensor from those trucks and rescaling the pulse signal in the ECM
Eric Brooks said we can do that in the HPTuners software
roberts
Oh okay. I was told there a change that I can get the speedo to work but it more than likely wont. So now I know that I'll see what u can do. Thanks. Hopefully u can do that in the sct
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Well a little update I got the transmission built
One of the aluminum drums I used. notice him much larger the input shaft is now and the splines.
New shifter is mounted
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
Doing a little work on the Rearend finally
1350 style Cobra pinion flange swapped over.
Spool
Girdle back on
Tiny 35 spline axles and 5/8" studs
Axle tube weld been holding up for over a year and a half of beating on big sticky tires [emoji39]
Lca relocation brackets filled in solid to factory brackets and gusseted.
Added tie-down strap rings to back of LCA brackets to make tie-down on trailer quick and easy.
