Stock cat exhaust pipes
dakotanut
Need some help. Do I buy, make or find someone with it to put back on my 06 Stang. Thanks.
MrAwesome987
Upstate SC
Do you have the stock exhaust manifolds? If so, I would try to return to the original catted H pipe if you need the cats. Where are you located, I have my original one I could sell.
dakotanut
I have the stock manifolds. I'm in Texas. S.W of Houston.
I'm assuming that you have an offroad midpipe, so you could just plumb in a pair of high flow cats e.g. Pypes in the same location that the stock cats would have been. Then you'd pass the inspection and emissions.
PonyBoy
Long Island, NY
Probably won't help you, but if someone else is interested I have original exhaust manifolds and H pipes with cats from 2010 4.6L. I am in NY
06 T-RED S/C GT
Carnegie, PA
It depends on what the state's requirements are. If the state in question does a visual inspection? they can legally fail the vehicle if they can determine the OEM mid-pipe has been removed or changed. There's also no guarantee that high-flow cats will pass the OBDII emissions test, especially those with 200-300 cells per square inch due to their higher flow rates over the stock cat's 600 cell per square inch. Personally, I really don't think that just plumbing in a pair of high-flow cats will be enough to pass the OBDII emissions test without adding a pair of spark plug non-foulers to the rear 02 sensors :shrug:
dakotanut
That's why I'm trying to find the stock pipe with cats. I can do the nonfoulers too but rather have the stock pipe for the smog test.
dakotanut
I bought the car this way and have no idea which of the previous 3 owners took them off.
Iceman62
Bullitt 6005
NE
There's got to be a salvage yard nearby somewhere...make a trip & pull some parts. Hell, we still have my son's 2016 stock exhaust hanging/taking up space in my garage...there are stock exhaust parts everywhere...just have to look/hunt.
