almost but still so far .
great job kyle very professional and great looking
job you are doing .
as far as my phaser i just dunno what happened , new phaser and bolt and
it was tight , for that locator pin to shear i just dont know .
Thank you,
Made some more progress yesterday, mocked up the cooling system less the radiator and pressurized it, found a leak at a new connection I made at the crossover tube, fixed it, and proceeded with testing. I was very pleased to confirm there are no more leaks! I know this is not really necessary but I'm still a little traumatized from breaking my previous two blocks.
Pressure testing octopus
modified additional cooling, the middle fitting is where the leak was. I decided to loop that back to the water pump rather than simply cork them figuring Ford circulated the coolant that way for a reason, with or without a heater. I didn't want to risk improper cooling so I simply bypassed the heater and looped the two connections together via -8an fittings and line.
Installing that pesky rear cover
Yes the gasket maker is on a little thick, I don't want it to leak! I cleaned it off on the inside after torquing the bolts down.
Oil pan installed. I had a brand new pan gasket and windage tray for 2013 GT 500 but found it was broken right out of the box! one of the rails was completely cracked and would have leaked like crazy. I got that from Steve @ Tasca but it was a long time ago I just never used it until now, and since oil touched it I'm probably SOL. In any case I had to clean and reuse my old one.
Balancer Installed
Headers, oil dip stick and motor mounts on, now she's pretty much ready to drop back into the car, maybe take a stab at it tonight or tomorrow.
Then I'll still need to finalize the front end alignment settings before I can drive it, check over the new brake system, and hope I did the wire tuck correctly, among other things that I'm probably forgetting right now! Oh and upload the new tune from LITO for the ID 1300's. And pump out the 4 month old e85 and replace it with fresh...the list goes on!
