TB Electronics swap question.
For those of you have swapped your electronics to a new TB, did u test and adjust the TPS voltage? I have read conflicting write ups as to do this.
TIA
dysan
Dis-Member
Williamstown, N.J.
When I swapped my tps from my stock throttle body to my edelbrock throttle body I didn't do any testing. Just worked.
Anyone else?
Back from a party, too many cold ones, ughhhh
Any reason that the electronics cannot be swapped on without removing the TB itself? Seems like all the write ups are for a swap of the TB, in my case I am leaving the TB as is, just the motor and housing are being replaced.
Cossiedriver
Autobahn User
Germany
Ii swapped the electronics of my TB without any adjusting... Works fine since 20k
Also did it for a friend of mine without any problems
Joerg
06silverbullet
orange county, ca
i've swapped several electronics on a few different throttle bodies. bbk 62mm and gt500 and stockers. i have never had to adjust anything. i've just made sure not to twist the t/b and make sure the spring was properly set. i've ran all those throttle bodies without a single hiccup. i think people having issues with throttle bodies have simply messed up their tps by not being careful enough.
Thanks guys. Got the swap done last night. Found some interesting things, if u look at my original DTC trouble thread for details.
Barricade
Decepticon Extraordinaire
The Alamo
I had to adjust the BBK and when I threw the FRPP on the Saleen it needs to be adjusted as well. uuuggghhhhhhhhhhhhhhhhhhhhhh
killr3v
Hector G.
Katy, TX
factory TB's shouldn't need adjustment. Only the older BBK TB's needed adjustment. FRPP's shouldn't either. I guess you just got lucky Barricade haha
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Stock GT tb to a Kenne Bell 130mm TB, straight swap-over with no adjusting. Just getting the clock-spring right was all that was needed.
