Th 400 swap list
Dillon Dollar
oklahoma
I found a good deal on a 1500 hp lentech 4r70w but I was told that anything over 1000 hp these transmissions fail
Sent from my SPH-L900 using Tapatalk
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
That is a lot....track only car or street car as well? Not a lot of people can handle 600+ RWHP let alone 1200!
Dillon Dollar
oklahoma
Mainly street car I daily drive a 800 hp Shelby sometimes so I'm used to power for the most part
That's pretty sweet man, I plan on ditching the F1A later down the road and goin with a custom twin turbo kit
Dillon Dollar
oklahoma
Does anyone know if anyone has done a th 350 instead of a th400
DTL
SoCal
Bringing this thread back to life to see if anyone has an answer for the speedometer when switching to a th400. I've heard of the computer freaking out without a speedo signal and pulling power. Can this be turned off with tuning or is there a way to generate a usable speedometer signal??
DTL
SoCal
I already have a transmission and I use Mike's out of Lancaster, CA.
DTL
SoCal
Thanks for the link. I think the 2011+ cars need to have the VSS signal or the computer freaks out.
Bud
Northern Colorado
Mine doesn't have a VSS signal and does fine now. The car was going into limp mode when we first got it together and tried to get on it though. Ken did some tweaks in the tune to fix it, not sure if it was related to no VSS or not.
Evolution Performance has a speedo working in their th400 swapped coyote I believe, might hit them up to see what they did to make it work if they are willing to share.
DTL
SoCal
All I see on their website is their crossmember. No mention of a complete kit. I'll try giving them a call on Monday and see what they say.
Bud: It's encouraging to hear that yours is running w/o a vss signal at all. Thanks!
Bud
Northern Colorado
I'd still like to have vss to be able log rpm vs mph for measuring converter slip. I have a cheap drive shaft sensor kit I was going to wire into the stock harness and see if we could tweak the holes setting into tune to make it read close to right. I may get back to trying to make it work someday....or just get a racepak for logging
DTL
SoCal
If all else failed, I was wondering if a racepak DS speed sensor could double as a vss output?
