tnsaleen's Official Build Thread: 700rwhp or Bust!
tnsaleen
Nashville, TN
Some pictures of the hotside. I still need to order a new wastegate, install o2 sensor bungs, the Y pipe, and cut out. Overly pleased with how rigid the kit is and how it turned out.
Sent from my XT1254 using Tapatalk
tnsaleen
Nashville, TN
Thank you. I am getting the hot side welded up by a buddy who welds for a living, and then it will be getting ceramic coated shortly after.
It took me close to 30 hours to make the hot side. First time for everything!
tnsaleen
Nashville, TN
Picked it up on Amazon for about $100. The mounts were all in the proper locations and the shroud is pretty nice. I haven't had any problems with it but I just got it on. In 92 degree humid traffic it does fine so far
1quick08
NJ
Awesome build,great work,id buy that turbo kit.Most of the kits sit too low,yours is perfect.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Yeah, if your turbo kit doesn't require modification of the front suspension and lets you keep the front sway bar, even I'd buy it.
tnsaleen
Nashville, TN
Haven't had time to work on the Saleen much. A few updates:
Motor is back from the machine shop. I got the white line adjustable swaybar endlinks on along with the sway bar relocation brackets. Installed koni yellows, H&R SS springs, and the hotside is welded up. I am waiting for the wastegate to come in and then it will go off to be ceramic coated, then the fun begins.
Also got the 95 style cobra r hood installed and the hood and front bumper should be done at the paint shop Wednesday!
Stainless intake and exhaust valves in the 08 heads.
