Makdaddy
I am Dysfunctional
What are you using to read actual temp? Mine does not display an actual number.
Head temp and water temp off of Aeroforce interceptor
The Aeroforce uses the PCM data stream so that should work. I don't think both sensors would be wrong. But you could use an ir temp gun or just a thermometer to see what the actual coolant temp is for comparison.
Haven't followed the whole thread and really not sure what the issue is, but I always recommend getting an electric Meziere pump to help with engine cooling. I know it's not that accurate, but my factory gauge has since moved to one notch below center where it used to sit and has never budged higher than that. It does get lower than that when I sit idling. With little heat being generated and the pump running at full speed actually lowers the temp which is opposite of most cars with a mechanical pump.
Hope that helps.
Have you replaced the radiator cap...?
When (or if) you removed the thermostat, did it help?
When you did your most recent testing, what was the air temps and humidity?
Well Ill be kicking myself if a $7 cap fixes thisBad radiator caps can cause weirdness. I replace all of mine at 50k miles now.
Sent from my Samsung Galaxy Note 4 using Tapatalk
WOOT WOOT
M-8C607-MSVT= FIXED
So we got the new fan in today
Only 82 degrees out but real muggy from all the rain
Car ran with the air on at 205 Head temp and 195 coolant temp
Its supposed to be 90 and hot tommorow
That will be the test
But Im confident its fixed. THANK GOODNESS
