Twin Snail Build...
1BADHRSE
New York
some new goodies: aen boost, msd 2 step and 63lb injectors
pulled the pan by dropping the front suspension...
drilled the holes for the drains:
siliconed, red loctites and fit the fittings:
1BADHRSE
New York
Hooked up all the down pipes, water and oil lines!!!!
downpipe drivers side:
msd 2 step harness tucked as best as possible...
one eyed willy
Pizzle fo shizzle
Lakeland FL
what size oil drian line are you using? are you going from a push line hose to a stainless steel line somwhere for the oil feed?
1BADHRSE
New York
Loking great man!
thanks man! You have a hell of a build yourself! Much more extras lol how's it coming!!!
are you oiling the turbos in sequence, or do you have two feed loops setup?
is that what you mean I have a pie like adapter inbetween my oil pressure sender with two 3an feed lines going to the turbos.. One feed line to each from th motor...
The drain lines are Russel/stainless in a few places, mostly a thick brake line type.. They don't say how large they are but they are considerably larger then the 3an and I can easily fit a few different fingers in them...
These came with the kit a d are actually molded perfect so not to touch the manifolds I will get some pictures of that tomorrow...
one eyed willy
Pizzle fo shizzle
Lakeland FL
Just picked up a turbosmart eboost2 thanks to RDKDesignsS197!!!
good choice, i just spent a few hours this past sunday really dialing in the "street" version for a little higher boost. it takes some patience, this setting effects that setting and yada yada yada, what tuner are you uaing, sct? have you datalogged at all before,if not you may want to go ahead and wire for it when you do the gauges,it will save you some headache from having to do it later. i wired up a 3 bar map sensor and my aem wideband on a firewire cable that coils up on the driver side access panel, when i datalog i just pull the cable out and run it over to the laptop.using the datalogging really helped me get the boost controller working good,just start the logging,go thru the gears,check it out and make adjustments,then do it again until it works right,took about 10 runs to get it dialed in good.it holds 15psi to redline.
1BADHRSE
New York
How are you hooking your Wideband and boost controller up to your laptop? I know they have the analog wires that you can tap into... I have datalogged before but was never good at it so I will get some practice...
My tuner only lives 30mins away though so I dont know whats best... I will probably end up trailering the car over there...
one eyed willy
Pizzle fo shizzle
Lakeland FL
i use a 3 bar map sensor and a aem wideband, im using a xcal 3 hooked up to a laptop, the boost controller is not on the laptop,just used the loggs from the laptop to help dial it in,alot easier to do with datalogging than just watching the boost gauge.what tuner do you have?if you have a xcal 3 i can tell you exactly how it wired up,real easy to do.
Shades
New York
Who are you having do your tuning?
(Sorry if you've answered this before, too many pages to go looking though)
1BADHRSE
New York
Yes I have a Xcal 3... I am interested to learn...
EFI logics in Bethel CT does my tuning...
He tuned me N/A and did a superb job...
Specializes in Evos, Stis, Fords, Mazdas and others...
Shades
New York
Yup I'm familiar with them, I've heard many good things as well.
1BADHRSE
New York
Thanks for the pictures man!!! That looks really good just make me want to get my piping done LOL!!!
Vashthe3rd
Maximum Trolling
willy does that mean your BOV is venting to the atmosphere?
That's pretty sick either way, and a superb location for it on the piping, no way you'd have any trouble with that.
Good move on the Eboost2 btw, a much better controller than the AEM one will ever be.
