Loking great man!
are you oiling the turbos in sequence, or do you have two feed loops setup?
what size oil drian line are you using? are you going from a push line hose to a stainless steel line somwhere for the oil feed?
is that what you mean I have a pie like adapter inbetween my oil pressure sender with two 3an feed lines going to the turbos.. One feed line to each from th motor...
yes that is exactly what i was looking for, thanks.
Just picked up a turbosmart eboost2 thanks to RDKDesignsS197!!!
My tuner only lives 30mins away though so I dont know whats best... I will probably end up trailering the car over there...
i use a 3 bar map sensor and a aem wideband, im using a xcal 3 hooked up to a laptop, the boost controller is not on the laptop,just used the loggs from the laptop to help dial it in,alot easier to do with datalogging than just watching the boost gauge.what tuner do you have?if you have a xcal 3 i can tell you exactly how it wired up,real easy to do.
Who are you having do your tuning?
(Sorry if you've answered this before, too many pages to go looking though)
EFI logics in Bethel CT does my tuning...
He tuned me N/A and did a superb job...
Specializes in Evos, Stis, Fords, Mazdas and others...
