Dubstep Shep
WUB WUB VROOM VROOM
Please review our posting rules
http://s197forum.com/forum/showthread.php?t=30272
http://s197forum.com/forum/showthread.php?t=10392
Moved
Nah, we never heard of it....
http://www.s197forum.com/forum/showthread.php?t=49583&highlight=Compound+boost
http://www.s197forum.com/forum/showthread.php?t=74321&highlight=Compound+boost
http://www.s197forum.com/forum/showthread.php?t=84151&highlight=Compound+boost
http://www.s197forum.com/forum/showthread.php?t=65335&highlight=Compound+boost
Thanks for the clarification. The titles are a bit deceiving.
Interestingly enough though, I didn't get a single result when I searched "twincharger"
This is something Ive researched a bit, and it is definitely nothing new. I found some pics of this being done that were on black and white film
Heres how it breaks down.
With a setup like this you get the advantage of having higher manifold pressures than the pressures found inside the turbo manifolds, due to the supercharger. So, just like with a normal supercharger setup, you get a lot of scavenging effect which helps make power and reduce heat by clearing the cylinder. This means more timing and/or more boost.
Also, the supercharger helps the turbo(s) spool easier, so you can run a higher A/R turbine housing, which make more power without sacrificing spool.
All together, if you have a supercharger running at low speed (wherever its most efficient), and the turbos on top of that making most of your boost, you can make lots of power with a nicely shaped powerband.
Its a cool idea and it does work well, but its also expensive and complex. As much as I like it, Im not sure Id ever do it, Im a road racer and I dont think I could ever justify the added weight up front.
EDIT:
Also, modern turbos have almost zero lag. Lag is different than being below boost threshold.
Exactly. Each cancels the disadvantages of the other, to an extent.
Without mincing technical terms, it takes turbos time to build up to their boost level, and by concept of the technology, that is unavoidable, though it's been minimized in many circumstances.
The way I see it you have all the power of a supercharger down low, that most turbo setups just don't produce, you reduce parasitic draw, and you get the power up high in rpms that turbos are known for.
Stuff's just expensive hahahaha.
