07torchgt
^MY NAME; THINGS I SAY>
- Joined
- Dec 28, 2007
- Posts
- 1,055
- Reaction score
- 4
New thread with new problem... well the knock sensors are no longer the issue... No more vibration and just to be sure my tuner turned the knock sensors off and I gave it a run and its still pulling timing... After looking at the graphs and cycling through the different logged parameters I found a pattern... Its pulling the timing when the voltage drops out... at 2500 the alternator stops output, then the voltage regulator resets and the timing climbs back up till it shuts down again and timing drops yet again... What would make the alternator shut down only under load...
. Isn't that the tuner's job to get it running right?
